2013 AUGI Top Ten Wish List Results
AutoCAD
  1. Carey Edwards - Help - AutoCAD Help needs more help
  2. Billy Wooten - Snaps - OSNAP for center of polygon
  3. Yair Yes - Drawing Tools - 2D Lock Drawing order of Specific Objects
  4. Donald Boyer - Modify - Modify a Cloud
  5. Jim Gerth - XREF - over-ride the over-rides
  6. Josh Crawford - Object Properties Manager - Don’t list XREF Layers when they can’t be selected
  7. Michael Shick - Dimensions - Text Wrap in Dimensions
  8. Ray Mendoza - Blocks - Visibility Parameter Enhancement
  9. Anita Nichols - MText - Set Format of Copied Text
  10. Jason Herringe - Other - Dynamic blocks in Multileaders
AutoCAD Architecture
  1. Kenneth Siegel - AEC Polygons - Polygon center
  2. Matthew Dougherty - Multi-View Blocks - Dynamic Array settings
  3. Nathan Ellery - Roofs - Update & Improve Roof Object Tool
  4. Nathan Ellery - Slabs - Improve Slabs
  5. A. K.  - Detail Components - Detail Component Manager acting like Properties Window or XREF Window
  6. Nathan Ellery - Doors - Improve Doors
  7. Melinda Heavrin - Spaces - Stretching Spaces
  8. Joe Perkins - Tools - Synchronized Tool Sets
  9. Melinda Heavrin - Walls - Walls under Style Manager/Display Properties
  10. Ron Filiatrault - Tools - Previous selection sets
AutoCAD Civil 3D
  1. James Lord - Feature Line - Dynamically link feature lines created via stepped offset.
  2. Chris Brenton - Pipe Network - I wish Civil3d pipes could lock inverts and slopes at points of interest.
  3. Steve Boon - Feature Line - Linetype Generation on Feature Lines
  4. Francesca Maier - Pipe Network - Connect pipes from different networks
  5. Mike Pryor - Profile Show intersecting profiles
  6. Jason Eggen - Profile Create Design Profile from a Polyline/Object within a Profile View.
  7. Fernando Ferreira - Corridor - Convert feature line to alignment/profile
  8. Sebastien Leonard - User Interface - Global STOP Function
  9. Kevin Mills - Other - Multiple VPORT Label Styles
Inventor
  1. Jim Durkin -  Make Inventor Compatrible with Multicore Processors
  2. David Gaskill - Other - We need an escape key to cancel commands
  3. Rick Hageman - Assemblies - Positionally Constrain a Slot to a Hole
  4. Kendred Cooper More Detailed Error mesages
  5. Josh Hunt - Assemblies Assembly Insert Constraint and Lock Rotation
  6. Xavier VENISSE - Assemblies - Show the “other” source of constraint conflicts.
  7. Maarten Verbunt -  Migration of Settings to new Release
  8. Michael Eck - API - Multiple Solid Bodies in a Sheet Metal Part
  9. Pasi Annila - Sheet Metal - Have Flat Pattern extents as parameters to be used in ie. part lists.
  10. Pasi Annila - Assemblies - Quickly constraint parts together with origin planes
Navisworks Manage
  1. Jason Matthews - Clash Detective - Clash Detection Groupings
  2. Daron Denton - Clash Detective - Zone Based Clashing
  3. Zoran Markovski - Animations - Watermark
  4. Michael Smith - Clash Detective - Clash auto Groupings
  5. Brooks Williams - Clash Detective - Run clash tests only on visible areas when model is sectioned
  6. Joe Perkins - Find Items - Find Items Dialog too sensitive
  7. Joe Perkins - Selection Inspector - Selection Tree folders
  8. Colin Magner - Redlining - Multi-user reviews of Models
  9. Michael Smith - Navigation Tools - Shortcut keys
  10. Colin Magner- Redlining - We need a cheaper Navisworks redliner
Revit Achitecture
  1. Bret Thompson - Site tools Site tools
  2. Robert Manna - Stairs Better railing functionality
  3. Rick Bulic -  Object Snap Between Two Points
  4. Alex Campbell - Walls - I wish there was greater control and flexibility for wall joins.
  5. Hans Andrasko - Architectural Family Contents/Components - Family Browser Enhancement
  6. Thomas Chuffart - Other - More control on formatting the schedule and use of different colors of text…
  7. Rick Bulic - Walls - Sloping Walls
  8. Nick Baxter - Walls - Custom Wall Joins
  9. Scott Sellars - Other - Utilize Dual Monitor Setup Properly
  10. John Blasquez - Annotation Tools - Text Editor
Revit MEP
  1. Colin Magner - MEP Mechanical Systems - (Mechanical) - Tell us why our systems are not well connected
  2. Aaron Bulla - Annotation Tools - Add a footer/notes section to schedules
  3. Daniel Rodriguez - MEP Electrical Circuits - (Electrical) - Calculate Length Thru Pipe, Duct, Conduit, Cable Tray, etc.
  4. Nick Crane - Other - Connectors accross a linked model
  5. Colin Magner - MEP Spaces - (Mechanical) - Spaces to cope with vertically irregular spaces better
  6. Daniel Rodriguez - MEP Electrical Circuits - (Electrical) - Create coordinated single-line diagrams.
  7. Eric Kuszewski - Other - Plan Regions should apply to pipe, duct, pipe accessories, pipe fittings, conduit, etc
  8. Mitchell Voss - Other - Keep my Parameters in order
  9. Le Hien Huynh - Other - Duplicate sheets in order to reduce customizing time and increase consistency.
  10. Kevin McGlothlin - Other - Fix Pipe up and down single line symbology
Revit Structure
  1. Rebecca Frangipane Revision Cloud Sketch
  2. Shaun Peppers - Beams - Grade Beam Object Class
  3. Allen Wear - Structural members - Make joist extended ends visible on coarse view.
  4. Rick Blankenship - Structural Family Contents/Components - Pier and Grade Beams
  5. Arnout van Ijsseldijk - Annotation Tools - tag alignment, all angles possible not just horizontal or vertical
  6. David Keller - Walls - Wall layers properties can be defined as architectural or structural
  7. Evalucia 2000 - Annotation Tools - Keep override even if dimension change
  8. Richard Mitchell - Concrete Modeling (cast in place) - Add a System Pier Family
  9. Steve Saltsman - Annotation Tools - Tag the elevation
  10. Rebecca Galvan - Concrete Modeling (cast in place) - TOP OF FOOTING ELEVATION
