Boost Productivity with HP Performance Advisor
Working smarter and faster are keys to bringing high-quality products to market. Any system performance issues can greatly cut into your productivity—and your ability to deliver solutions on time and on budget.
HP Performance Advisor lets you spend more time focused on your work and less time waiting for your system by helping you maximize each subsystem performance through recommended settings. Best of all, these settings are based upon your specific application.
With this powerful productivity tool you can optimize your workstation to the Autodesk® applications you use by easily configuring and tuning your system. The tool catalogs the applications installed on your system and makes recommendations for drivers and performance tweaks that will allow your workstation to work better with the applications you use most.
At the same time, HP Performance Advisor allows you to monitor how your applications are performing on your workstation so you can make adjustments or perform upgrades to improve the overall performance of your system.
And should you need to troubleshoot a workstation or application problem, HP Performance Advisor provides complete system configuration information on a single screen, which helps to reduce the amount of time and effort you expend resolving the issue. You can also email the information directly to HP and Autodesk technical support personnel who are available to analyze and help you repair your system.
Performance Advisor is available in multiple languages, which allows for personnel around the world to take advantage of its powerful functionality. It comes pre-installed on all new HP systems and can be downloaded for any HP Workstations you already own.
Learn how you can improve your workstation performance by accessing the HP Performance Advisor website. And visit the HP for Autodesk website to read more about the HP Workstation family.
