Collaboration with Autodesk Design Review
First of all, what is Autodesk® Design Review?  Autodesk Design Review 2012 is a free program used to create and review DWF files.  DWF (Design Web Format) is an open, published, and secure file that enables you to combine and publish 2D- and 3D-design data and share it with others.  Much like Adobe PDF files, DWF files are no more alterable than printed paper copies.  However, unlike PDF files, DWF files retain detailed design information and scale.  This makes them more suitable for architects, engineers, and designers.
When DWF drawings are marked up in Autodesk Design Review, you can then view these markups in AutoCAD® Architecture and make changes to your drawings.  How does this work?  When you want to submit designs for review, you can publish a DWF file from AutoCAD Architecture and then send it to the reviewer of your designs. The reviewer can open the DWF file in Autodesk Design Review, mark up the file electronically and then send it back to you.  When you open the marked up DWF file in AutoCAD Architecture, you can view the redline markups in the AutoCAD Architecture drawing area, turn them off, make your changes, and republish the DWF file to send out for another review.  Doing all this electronically using AutoCAD Architecture and Autodesk Design Review will greatly decrease time normally spent in collaboration with others.
Publish Drawings for Review
Once your design is complete in AutoCAD Architecture, it is time to publish the drawings for review.  To ensure that electronic markups created in Autodesk Design Review align with the original drawing geometry, it is important not to change elements in your drawing file that can affect this alignment after you have published the DWF file for review.  These elements include the following:
• Layers and layer states
• Layers to which objects are tied
• View rotation
• Number and placement of viewports in layouts
• Position and scale of objects within viewports
To publish a drawing set in AutoCAD Architecture to a DWF file, select the Output tab on the ribbon and on the Plot panel, select Batch Plot (see Figure 1).  This brings up the Publish dialog box.  If the Automatically Load All Open Drawings option is selected in the Publish dialog box, all the layouts in the current drawing are listed in the sheet list.  You can modify the list of sheets in the Publish dialog box, as needed.  When your list of drawing sheets is assembled and configured the way you want for your drawing set, click the Save Sheet List button (see Figure 2).  In the Save List As dialog box, enter a name for the list in the File Name box and then click Save.  The drawing set list is saved as a drawing set descriptions (DSD) file.  Now, in the Publish dialog box, under Publish To, select DWF File.  Then click Publish.  Next, in the Specify DWF File dialog box, enter a file name.  The Files of Type is DWF based on the selected DWF format.  Click Select to provide the name and destination for the DWF file.  Click Save to start the electronic drawing set creation.
Figure 1: Batch plot
Figure 2: Publish dialog box
Insert Markups
A markup can be either a single comment or a redline geometry correction that is inserted into a DWF file.  Once the AutoCAD Architecture drawing has been published for review, you can use Autodesk Design Review to add markups electronically, just as you would mark up a paper version of the drawing.  You can also assign a status to the markup and add comments.  After you have made the markups you wish to make, resave the DWF file.  Now the markups can be viewed and corrections made.  Markups can be made using the Markup & Measure tab on the ribbon (see Figure 3).
Figure 3: Markup & Measure tab
View Markups
Now that you have received markups, it is time to review them so corrections can be made.  To view the markups in your designs, load the markup set into the Markup Set Manager.  (A markup set is a group of markups contained within a single DWF file.)  To open the Markup Set Manager, select the View tab on the ribbon in AutoCAD Architecture, then click the Markup Set Manager button on the Palettes panel.  This brings up the Markup Set Manager palette (see Figure 4).
Now, in the Markup Set Manager, click the Markup Set list control and select Open.  When you load a markup set into the Markup Set Manager, the tree view will display each marked up drawing sheet and its associated markups.  It is important to note that if you try to load a markup set by opening a DWF file that does not contain markups, you will not be able to open the DWF file in AutoCAD Architecture. You can, however, open the DWF file in the DWF file viewer.
While in the Markup Set Manager, you can view details of an individual markup.  To do this, click on an individual markup node.  The Markup Details area in the lower portion of the Markup Set Manager will display details for the selected markup.  These details can include creator of the markup, date and time it was created, and any comments associated with the markup.  It is important to note that markups are color-coded and have icons that are specific to their status (see Figure 5).
When you double-click a model space markup in the Markup Set Manager, the original drawing file opens in model space.  The drawing automatically reverts to the view rotation that was current when the drawing was published. Note that if you then change the view rotation, the markups will not be shown in the drawing until you double-click a model space markup and revert to the published view.  Also, note that visual style and Shademode must be set to 2D Wireframe.
The Markup Set Manager allows you to specify what is displayed in the drawing area.  You can show or hide the originating drawing file, the reviewed DWF file geometry, and the redline geometry. This allows you to view the redline geometry, turn it off to make the changes in your drawing file, and then view the redline geometry again in AutoCAD Architecture to check your corrections.  If you wish to hide DWG geometry for drawing sheets with associated markups, click the View DWG Geometry button.  You can click the same button again to show the DWG geometry.  If you wish to show DWF file geometry in the drawing area, click the View DWF Geometry button to show the DWF geometry.  You can click the same button again to hide the DWF geometry.  If you wish to show or hide redline geometry (markups) in the drawing area, click a markup node to view the redline geometry in the drawing area.  Then click the View Redline Geometry button to hide the redline geometry.  You can click the same button again to show the redline geometry.
Figure 4: Markup Set Manager
Figure 5: Color-coded markups
Respond To Markups
Now that you have reviewed markups, you can change their status and add comments that are saved with the markup.  In the Markup Set Manager, select an individual markup in the tree view and the Markup Details area displays information about the markup.  In this area, you can change the status of the markup or you can right-click on a markup and select an option on the Markup Status shortcut menu.  You will notice that the default status for new markups is <None>.  A markup’s status can be changed to Question, For Review, or Done.
In the Markup Set Manager, you can add comments or notes for the selected markup in the Notes area under Markup Details.  Changes in markup status as well as added comments are automatically saved in the DWF file and are included when you republish it.  Markup changes can also be saved by right-clicking the markup set node and clicking Save Markup History Changes on the shortcut menu.
Republish A Markup Set
After you have viewed a markup set and made necessary changes to your drawings, you can then republish the markup set for another review, if needed.  It is important to note that when you republish the markup set, the markups and any changes that have been made to them are saved in the DWF file. When anyone reviews the republished DWF file in Autodesk Design Review, the changes that have been made to the drawings are visible as well as any changes that have been made to the status and the details of the markups.  If you republish a DWF file that has had sheets deleted from it or rearranged within it in Autodesk Design Review, the new order of sheets will be reflected in the republished DWF file.  However, if any sheets were added to the DWF file in Autodesk Design Review, those sheets will not be included in the republished DWF file.
To republish a markup set, click the Republish Markup DWF button at the top of the Markup Set Manager.  Next, select one of the following:
• Republish All Sheets – Clicking this option republishes all sheets within the marked up DWF.
• Republish Markup Sheets – Clicking this option republishes only those sheets in the marked up DWF file that have associated markups.
Then, in the Specify DWF File dialog box, select a DWF file or enter a name for the file and click Select.  By default, the previously created marked up file name is displayed and is overwritten with a file of the same name that contains the drawing and markup changes.
Print A Drawing With Markups
If you desire, you can print a drawing with markups.  Begin in Windows Explorer and double-click a DWF file that contains markups.  The DWF file will open in Autodesk Design Review.  You can then print the marked-up DWF file.
As you are in the final stages of a design, drawings can be published for review.  Then you can receive corrections and comments electronically.  These can then be implemented and you can respond to these comments and then republish your drawings.  Doing all this electronically streamlines communication and results in a more efficient design process.  What better way to accomplish this than through the use of AutoCAD Architecture and Autodesk Design Review?  If your company is looking at “going green,” this is a perfect solution to stop printing all those paper drawings for markup and review.
