Heads Up - June 2012
Autodesk 2013 Products
2012-Mar-26 Autodesk IPv4 Network License Manager for Windows
http://goo.gl/VHFEX
2012-Mar-26 Autodesk IPv6 Network License Manager for Windows
http://goo.gl/p2hgN
AutoCAD® 2012
2012-May-24 AutoCAD 2012 Service Pack 2
http://goo.gl/KWwpx
2012-Mar-13 AutoCAD and AutoCAD LT 2012 SP1 SMB V2 Hotfix
http://goo.gl/21ocM
2011-Dec-13 AutoCAD and AutoCAD LT 2012 SP1 Ribbon Hotfix
http://goo.gl/OK7jQ
AutoCAD LT® 2012
2012-May-25 AutoCAD LT 2012 Service Pack 2
http://goo.gl/JfdwC
http://goo.gl/1Fj8a
Autodesk® Revit® Architecture 2012
2012-May-10 Hotfix - Autodesk Revit 2012 - Sketch Grid Performance
http://goo.gl/WQzh8
2012-Apr-16 Hotfix - Autodesk Revit 2012 - Material ODBC Export
http://goo.gl/xPnv8
http://goo.gl/C4lne
2012-Mar-09 Hotfix - Autodesk Revit 2012 - Point Clouds
http://goo.gl/L4B9u
2012-Feb-21 Hotfix – Autodesk Revit 2012 – Improves stability when working with large datasets (64-bit only)
http://goo.gl/2G4sl
Autodesk® Inventor® Professional 2013
2012-May-21 Mold Design Content Libraries for Autodesk Inventor Professional 2013
http://goo.gl/O9IaO
2012-May-08 Hotfix - CurrentCulture does not honor Formats setting in Region and Language
http://goo.gl/3qg1F
2012-May-02 Hotfix - Unexpected exit resulting from removing default Material/Appearance Libraries
http://goo.gl/DIFoj
2012-Mar-27 Hotfix - Entitlements not refreshed by license escalation with Inventor Optimization as a result of the dynamic licensing mechanism
http://goo.gl/cqXwF
Autodesk® Inventor® Professional 2012
2012-May-28 Autodesk Inventor 2012 Service Pack 2
http://goo.gl/vI3Gq
2012-May-23 Autodesk Inventor 2012 Service Pack 1
http://goo.gl/jr6mR
2012-May-08 Hotfix - iLogic BOM override is inconsistent
http://goo.gl/YyjSY
2012-Apr-25 Hotfix - GeneralDimensions.AddLinear errors out when passing intent created on 3D sketch geometry
http://goo.gl/11cxP
2012-Apr-03 Hotfix - Unable to set alpha channel option when writing out png file
http://goo.gl/ZHSMX
http://goo.gl/3YKeX
http://goo.gl/4XVcv
AutoCAD® Architecture 2013
2012-Apr-25 AEC Section Display Hotfix
http://goo.gl/2myYe
2012-Apr-16 AutoCAD Architecture 2013 & AutoCAD MEP 2013 Content Browser Migration Hotfix
http://goo.gl/QAFpU
http://goo.gl/OsTIM
AutoCAD® Architecture 2012
2012-Apr-12 Insert Dynamic Block Scale Hotfix for AutoCAD Architecture 2012 Service Pack 1
http://goo.gl/Jyrd5
http://goo.gl/aJAjW
2012-Feb-06 AutoCAD Architecture 2012 AEC Dimension Hotfix
http://goo.gl/VMQeM
2012-Jan-23 Service Pack 1 Silent Installation (Nordic Version Only)
http://goo.gl/GoeQd
AutoCAD® Civil 3D® 2013
2012-Apr-24 AutoCAD Civil 3D 2013 Survey Hotfix
http://goo.gl/xqzwB
http://goo.gl/rYlJf
AutoCAD® Civil 3D® 2012
http://goo.gl/GWuoS
2011-Dec-08 Autodesk 2012 Content Explorer Service Hot Fix 2
http://goo.gl/N7hj5
AutoCAD® Map 3D 2013
2012-Apr-03 FDO SQL Server Spatial Provider HotFix
http://goo.gl/8mROv
http://goo.gl/Hiiz1
AutoCAD® Map 3D 2012
http://goo.gl/Md4tj
http://goo.gl/QyS0E
AutoCAD® Mechanical 2012
2011-Nov-14 AutoCAD 2012 Performance Slowdown Hotfix (32/64 bit)
http://goo.gl/IuMss
2011-Oct-27 AutoCAD Mechanical 2012 Service Pack 1
http://goo.gl/P8nQu
Autodesk® 3ds Max® 2013
2012-Apr-19 Autodesk 3ds Max 2013 Product Update 1
http://goo.gl/VdRvq
http://goo.gl/e5ZkH
Autodesk® 3ds Max® 2012
2012-Apr-24 Autodesk 3ds Max 2012 Product Update 6
http://goo.gl/NiI4n
http://goo.gl/MSCav
2011-Oct-25 Autodesk 3ds Max 2012 Service Pack 2
http://goo.gl/FxPNm
Autodesk Alias Design 2013
2012-Apr-16 Hotfix - Help links in Alias 2013 incorrectly point to 2012 Wiki content and unexpected exit when use of “Use Embedded File Setting”
http://goo.gl/dPxCN
http://goo.gl/dPxCN
http://goo.gl/0EbRK
Autodesk® Alias® 2012
2011-Aug-09 Alias 2012 SP1
http://goo.gl/Q7cWK
2011-Aug-03 Hotfix - Unable to open CATIA V5 R20 files with DirectConnect 2012
http://goo.gl/9Cssc
2011-Jul-08 Hotfix - Import shrink option not functioning properly with DirectConnect 2012
http://goo.gl/0FsRS
Autodesk® Maya® 2012
2012-Mar-01 Backburner 2012.1.1
http://goo.gl/Rllyc
2012-Jan-25 Autodesk Maya 2012 Service Pack 2
http://goo.gl/qhN9p
2011-Oct-11 Autodesk Maya 2012 Service Pack 1
http://goo.gl/DarDG
Autodesk® Navisworks® Manage 2012
2011-Dec-19 Clash HTML Tabular Report hotfix
http://goo.gl/5kP4E
2011-Sep-12 Autodesk® Navisworks® 2012 Service Pack 1
http://goo.gl/IEEwN
2011-Mar-22 Autodesk IPv6 Network License Manager for Windows
http://goo.gl/oyRaB
Autodesk® Vault 2013
2012-Apr-23 Hotfix - Localized Help
http://goo.gl/xwLno
2012-Apr-13 Hotfix: Unable to install English product from French/German Vault For AutoCAD product.
http://goo.gl/2vFaj
http://goo.gl/fSlgf
http://goo.gl/nBhGY
2012-Mar-28 Hotfix – VE Folder Properties
http://goo.gl/qfxrl
2012-Mar-28 File Revision Hotfix
http://goo.gl/ADtKc
Autodesk® Vault 2012
2012-Feb-22 Multi Issue Hotfix
http://goo.gl/f0owT
2011-Nov-30 Suites Update
http://goo.gl/WgRnX
2011-Nov-17 Update 1
http://goo.gl/tmp8L
2011-Sep-30 Autoloader Update
http://goo.gl/vIteu
