Heads Up: Updates, Service Packs and Top Known Issues
Autodesk 2013 Products
2012-Mar-26 Autodesk IPv4 Network License Manager for
Windows
http://goo.gl/VHFEX
2012-Mar-26  Autodesk IPv6 Network License Manager for
Windows
http://goo.gl/p2hgN
AutoCAD® 2012
2012-Mar-13  AutoCAD and AutoCAD LT 2012 SP1 SMB V2
Hotfix
http://goo.gl/21ocM
2011-Dec-13  AutoCAD and AutoCAD LT 2012 SP1 Ribbon
Hotfix
http://goo.gl/OK7jQ
2011-Dec-08 Autodesk 2012 Content Explorer Service Hotfix 2
http://goo.gl/RVIw6
2011-Sep-27  AutoCAD 2012 Service Pack 1
http://goo.gl/jM8kC
2011-Jul-13  AutoCAD 2012 Block Editor Save Corruption Hotfix
http://goo.gl/U47H5
2011-Apr-01  Autodesk 2012 Content Explorer Service Hotfix
http://goo.gl/6zU76
2011-Mar-23  Autodesk Material Library Medium Resolution Image
Library 2012
http://goo.gl/cHnq3
AutoCAD LT® 2012
Hotfix
http://goo.gl/1Fj8a
http://goo.gl/5WXMh
2011-Sep-27  AutoCAD LT 2012 Service Pack 1
http://goo.gl/WuDx4
Autodesk® Revit® Architecture 2012
2012-Mar-09  Hotfix - Autodesk Revit 2012 - Point Clouds
http://goo.gl/L4B9u
2012-Feb-21  Hotfix – Autodesk Revit 2012 – Improves stability
when working with large datasets (64-bit only)
http://goo.gl/2G4sl
2011-Dec-13  Hotfix - Autodesk Revit Server 2012 - Improve
stability when uploading to Revit Server
http://goo.gl/dCJCS
2011-Oct-11  Hotfix – Autodesk Revit 2012 – Apply material
family parameters using the Paint tool
http://goo.gl/Oduwc
2011-Jul-13 Revit Architecture 2012 Deployment Utility
http://goo.gl/4UBPQ
2011-Jul-13 Hotfix - Incorrect Ribbon Icons
http://goo.gl/eR6IK
Autodesk Inventor® Professional 2013
2012-Mar-27 Hotfix - Entitlements not refreshed by license
escalation with Inventor Optimization as a result of
the dynamic licensing mechanism
http://goo.gl/cqXwF
2012-Mar-09  Mold Design Content Libraries for Autodesk Inventor
Professional 2013
http://goo.gl/O9IaO
Autodesk Inventor® Professional 2012
2011-Dec-12  Hotfix - Multiple Issues Addressed (see Summary and
readme file)
http://goo.gl/z33ow
2012-Feb-23 Hotfix - Unexpected exit when opening drawing file &
drawing browser stability enhancements & Unable to
use API to create GeometryIntent for curves
http://goo.gl/gDDK0
2012-Feb-16 Hotfix - Assembly created in Productstream
Professional 2011 fails to open in Inventor 2012
http://goo.gl/hxTA8
2012-Feb-16  Hotfix - Poor performance in Tube and Pipe update
http://goo.gl/VYGi2
2012-Feb-03  Hotfix - ScreenUpdating property changes to True
when another window gets the focus & stabilty issues
(see Summary)
http://goo.gl/GdExi
2011-Nov-23  Hotfix - Task Scheduler Check-In corrupts BOM/
Error 1200 on Item Assign & Cannot use the iLogic
Add Rule
http://goo.gl/44F3b
2011-Nov-18 Hotfix - Projected edge will not select as a closed loop
for offset
http://goo.gl/G6fk0
2011-Nov-29  Hotfix - Multiple Issues (see Summary and readme file)
http://goo.gl/O6BT7
AutoCAD® Architecture 2012
2012-Feb-06 AutoCAD Architecture 2012 AEC Dimension Hotfix
http://goo.gl/VMQeM
2012-Jan-23  Service Pack 1 Silent Installation (Nordic Version
Only)
http://goo.gl/GoeQd
Hotfix
http://goo.gl/6mfcE
2011-Dec-08  Autodesk 2012 Content Explorer Service Hot Fix 2
http://goo.gl/IHfzF
2011-Nov-14  AutoCAD 2012 Performance Slowdown Hotfix
(32/64 bit)
http://goo.gl/HlZTY
2011-Sep-29 AutoCAD Architecture 2012 Service Pack 1
http://goo.gl/Qf2zm
2011-Aug-30  AutoCAD Architecture 2012 & AutoCAD MEP 2012 - Localization Hotfix: Corner Windows
http://goo.gl/cJmEU
AutoCAD® Civil 3D® 2012
Hotfix
http://goo.gl/GWuoS
http://goo.gl/N7hj5
2011-Dec-08  AutoCAD Civil 3D 2012 Update 1
http://goo.gl/AkgDX
(32/64 bit)
http://goo.gl/Ebi47
2011-Sep-07 Hotfix - Prospector Lock-up
http://goo.gl/T2mTx
1-Jul-13  AutoCAD 2012 Block Editor Save Corruption Hotfix http://goo.gl/G6hpz
2011-Jun-23  Autodesk Infrastructure Design Suite Network
License Hotfix
http://goo.gl/yJ54v
AutoCAD® MAP 3D 2012
2011-Dec-13 AutoCAD and AutoCAD LT 2012 SP1 Ribbon Hotfix
http://goo.gl/Md4tj
http://goo.gl/QyS0E
2011-Sep-14 Localized UI Hotfix
http://goo.gl/ER6Ek
2011-Aug-10  Autodesk® Infrastructure Administrator 2012 Feature Rule “Check Perimeter” Hotfix (for AutoCAD Map 3D 2012)
http://goo.gl/2QlRN
AutoCAD® Mechanical 2012
(32/64 bit)
http://goo.gl/IuMss
2011-Oct-27  AutoCAD Mechanical 2012 Service Pack 1
http://goo.gl/P8nQu
http://goo.gl/kRUzk
2011-May-11  Localization Hotfix for AutoCAD Mechanical 2012
Chinese Simplified, Chinese Traditional and Korean
32bit - Side-by-Side with AutoCAD Mechanical 2011
http://goo.gl/tZ1HH
Autodesk® 3ds Max® 2012
2011-Oct-25  Autodesk 3ds Max 2012 Service Pack 2
http://goo.gl/FxPNm
2011-Sep-29  Backburner 2012.1
http://goo.gl/yTVIV
2011-Sep-23  Hotfix 1 – Autodesk® 3ds Max® 2012
http://goo.gl/nzMVl
2011-Sep-23  Hotfix 2 – Autodesk® 3ds Max® 2012
http://goo.gl/HVJkx
Autodesk® Alias® 2012
2011-Aug-09  Alias 2012 SP1
http://goo.gl/Q7cWK
2011-Aug-03  Hotfix - Unable to open CATIA V5 R20 files with DirectConnect 2012
http://goo.gl/9Cssc
2011-Jul-08  Hotfix - Import shrink option not functioning
properly with DirectConnect 2012
http://goo.gl/0FsRS
2011-Jun-17  Hotfix - Imported B-Spline surfaces from CATIA V5
are over extended with DirectConnect 2012
http://goo.gl/x9zCR
Autodesk® Maya® 2012
2012-Mar-01  Backburner 2012.1.1
http://goo.gl/Rllyc
2012-Jan-25  Autodesk Maya 2012 Service Pack 2
http://goo.gl/qhN9p
2011-Oct-11  Autodesk Maya 2012 Service Pack 1
http://goo.gl/DarDG
2011-Aug-12  Composite 2012 Hotfix
http://goo.gl/HTBfc
DirectConnect 2012
http://goo.gl/o4YFy
2011-Aug-01 Autodesk Maya 2012 Hotfix 4
http://goo.gl/eKtZT
Autodesk® Navisworks® Manage 2012
2011-Dec-19  Clash HTML Tabular Report Hotfix
http://goo.gl/5kP4E
2011-Sep-12  Autodesk® Navisworks® 2012 Service Pack 1
http://goo.gl/IEEwN
2011-Mar-22  Autodesk IPv6 Network License Manager for
Windows
http://goo.gl/oyRaB
Autodesk® Vault 2013
2012-Mar-28  Hotfix – VE Folder Properties
http://goo.gl/qfxrl
2012-Mar-28  File Revision Hotfix
http://goo.gl/ADtKc
Autodesk® Vault 2012
2012-Feb-22  Multi Issue Hotfix
http://goo.gl/f0owT
2011-Nov-30  Suites Update
http://goo.gl/WgRnX
2011-Nov-17  Update 1
http://goo.gl/tmp8L
2011-Sep-30  Autoloader Update
http://goo.gl/vIteu
2011-Sep-30  DWG UDP Update
http://goo.gl/1ljfP
