Sponsor Spotlight: HP Monitors: See Your Designs in a Whole New Light
Are you concerned that your current system monitors are holding you back from properly visualizing your drawings and illustrations?
If so, then HP Performance Series Monitors can help. This new line of HP ZR monitors allows you to add more color into your designs through the use of state-of-the-art technology that delivers enhanced display quality and clarity.
These displays feature in-place switching (IPS) backlit LED technology that provides you with a broader viewing angle range. This means that colors are clearer and you can achieve a better color representation as your eye moves off axis(1).
The HP ZR monitors also offer full HD resolution(2) and ultra-wide viewing angles that provide crisp and clear high-definition views of your applications and multimedia content. And with super fast response times, these monitors reduce the ghosting, blurring, and smearing that can occur in other monitors.
Starting at a low price point, these monitors are also a cost-effective solution if you want to use a two-monitor configuration to increase the viewable size of your usable desktop.
The HP ZR monitors were designed to complement the functionality of your HP Z Workstations. Extensive testing helps deliver seamless operation with the HP Z Workstations line and the applications you use most.
These monitors were also created with the environment in mind. They provide 85 percent efficient power supplies, are ENERGY STAR® certified, and feature BFR/PVC-free displays/stands(3).
Find out more about the HP Performance Series Monitors and select from a variety of monitors.
(1) As compared to mainstream monitors with TN (Twisted Nematic) panels when viewed at 60°.
(2) HD content is required to view HD images.
(3) Meeting the industry definition of 'BFR/PVC-free' per the iNEMI Position Statement on "Low Halogen" Electronics.  Plastic parts incorporated into the chassis generally contain < 1000 ppm (0.1%) of bromine or chlorine.  Printed circuit board and substrate laminates generally contain < 1500 ppm (0.15%) of total bromine and chlorine.  External cables (power, video and USB) are not BFR/PVC-free. Service parts after purchase may not be BFR/PVC-free.
