HP Z220 Workstations - More power, less energy, still affordable
HP Z220 Workstations Help You Do More While Using Less
To run your Autodesk applications properly requires a workstation that delivers high levels of power and reliability. With the HP Z220 Workstation, you get that – plus the system performance, expandability, and energy efficiencies you want – all at prices that rival a standard desktop PC.
Available as a convertible minitower or small form factor system that is 65 percent smaller, the HP Z220 Workstation offers great flexibility and a choice of enterprise-class features that are tested and certified to run a wide range of Autodesk applications.
Built on Intel® Xeon® processor E3-1200v2 family and 3rd generation Intel® Core™ i7 processors (1), the HP Z220 Workstation offers features such as Intel® Turbo Boost (2), which delivers some of the fastest processing speed for single and multi-threaded applications. And Intel® Smart Response Technology, a disk cache solution, provides faster boot up times and quick application responsiveness (3).
These systems also provide enterprise-class memory technologies, high-speed storage, and integrated Intel® HD Graphics and discrete professional 2D and 3D graphics options from NVIDIA and AMD. And the unique tool-free chassis of the HP Z220 Workstation makes adding hard drives and upgrading memory simpler and faster.
The HP Z220 Workstation also comes with tools designed to help improve your productivity. For example, HP Performance Advisor keeps your system operating at its peak potential by allowing you to configure, customize, and optimize your workstation. And HP Remote Graphics Software give you access to your 2D, 3D, video, and media-rich applications when and where you need them.
To learn more about the HP Z220 Workstations, visit the HP Workstation website.
_________
(1) Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel® architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel® 64 architecture. Processors will not operate (including 32-bit operation) without an Intel® 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
(2) Intel Turbo Boost technology requires a PC with a processor with Intel Turbo Boost capability. Intel Turbo Boost performance varies depending on hardware, software, and overall system configuration.
(3) Requires a compatible Intel® Core processor, enabled chipset, Intel® Rapid Storage technology software and non-SED HDD + optional mSATA SSD flash cache module and non-WWAN configuration. Intel® Smart Response Technology is only available on select 2012 HP systems. Depending on system configuration, results may vary.
