Inside Track—November 2020
Welcome to the AUGI Inside Track! Check out the latest opportunities to advance your skills, processes, and workflows in your firm, with the most current AEC-related software and hardware updates available.
Structural Analysis Toolkit 2020
https://apps.autodesk.com/RVT/en/Detail/Index?id=7354987843996725256&appLang=en&os=Win64
Autodesk Revit: 2020
Robot Structural Analysis Professional: 2020
The toolkit includes the following components:
Link with Autodesk® Robot™ Structural Analysis Professional - Use it to perform advanced analyses after transferring an Autodesk® Revit® analytical model to Autodesk® Robot™ Structural Analysis Professional (Robot). It is a structural analysis and design software application. It enables you to perform linear and nonlinear analyses of any structure type and shape and to design steel, concrete, and timber elements of a structure.
Structural Results Storage and Exploration tools - Use Results Manager to review, download, or remove results packages. Use Results Explorer to display result maps and diagrams on elements of an analytical model in Revit.
Apply Current Date
https://apps.autodesk.com/ACD/en/Detail/Index?id=5389778018590636442&appLang=en&os=Win32_64
Versions: 2021, 2020, 2019, 2018, 2017 of the following:
Autodesk AutoCAD
Autodesk AutoCAD Electrical
Autodesk AutoCAD Mechanical
Autodesk AutoCAD Architecture
Autodesk AutoCAD MEP
Autodesk® Civil 3D®
Autodesk AutoCAD Plant 3D
Autodesk AutoCAD P&ID - Version: 2017
After typing the ADA command, Autodesk® AutoCAD® will prompt to select attribute, multiline text, or text object to apply current date. Program starts with default format date Day.Month.Year (07.23.2013). All commands:
  • ADA - main shortcut,
  • ADAF - 'Format' window, in this window user can select predefined format date,
  • ADAE - 'Edit' window, used to edit list of dates (move items up, down, delete or 'Add date' window)
  • ADAA - 'Add date', used to add new format date,
  • -ADA - all commands are combined under one.
iPrint
http://www.dnsistemi.com
Autodesk Inventor: 2021, 2020, 2019, 2018
Autodesk Inventor Professional: 2021, 2020, 2019, 2018
iPrint is an add-in that allows you to speed up and simplify all printing processes in an easy way.
Classic printing takes a long time because you must open the designs one at a time, set up the printers and finally launch the print.
All these long and tedious operations are completely abolished with iPrint as it takes care of doing these operations for you. It also allows you to make partial prints by selecting only the documents or sheets you want to print.
The use of the add-in is extremely simple and intuitive. Just open the assembly you want to start from and click on the print button. The add-in shows the entire document hierarchy and allows you to decide which documents to print and which to not print.
The capabilities of iPrint are not limited to printing but also allows you to define the order in which the drawings will be printed, for example in alphabetical order, list order, etc.
Last but not least, iPrint allows you to enter the quantity of components directly into the drawing. The quantity is calculated before printing and added only for as long as it is necessary and then removed.
If you have some news to share with us for future issues, please let us know. Likewise, if you are a user of a featured product or news item and would like to write a review, we want to know. brian.andresen@augi.com
  • AUGIWORLD
