Sponsor Spotlight: HP Z Workstations and AMD graphics help bring your designs to life
In today’s professional and technical workplaces, designs and models are becoming more complex and detailed. Which is why you need advanced systems and graphics capabilities that help you stay ahead of the curve and meet the increasingly demanding challenges.
The combination of HP Z Workstations and AMD professional graphics help boost your productivity and unleash your creativity.
AMD FirePro™ 3D graphics offer high-speed memory, a parallel processing architecture, and support for simultaneous monitor outputs from a single graphics card using AMD Eyefinity multi-display technology.1
You can choose from a range of graphics cards that deliver the features and reliability you need to get the job done. For example, the AMD FirePro V3900, which is backed by 1 GB of fast DDR3 memory, 480 stream processors, and support for up to five display devices, is designed for those of you working with low to moderately complex designs.
If you’re creating medium to large models, then the AMD FirePro V4900 is perfect – with 1 GB of GDDR5 memory, 480 stream processors, and support for three simultaneous monitor outputs.
And the AMD FirePro V5900 professional graphics card, which features 2 GB GDDR5 memory, 512 stream processors, and support for three simultaneous monitor outputs, is just right if you’re working with a broad range of applications, complex models, and advanced visual effects.
As important, these graphics are tested and certified to run the most demanding Autodesk® applications on your HP Z Workstations – ensuring you get the job done on time and on budget. HP also provides a full three-year warranty for these graphics cards.
Learn more about the powerful combination of HP Z Workstations and AMD graphics by visiting the HP Workstation website.
1 - AMD Eyefinity technology can support multiple displays using a single enabled AMD FirePro professional graphics card; the number of supported displays varies by card model. Requires AMD discrete graphics configuration. Total number of screens supported varies by model.
Microsoft Windows 7, Windows Vista, or Linux is required in order to support more than two displays. Depending on the card model, native DisplayPort™ connectors and/or certified DisplayPort active or passive adapters to convert your monitor’s native input to your card’s DisplayPort or Mini-DisplayPort connector(s) may be required. See www.amd.com/firepro for details.
  • Sponsor Spotlight
